Seem to have a fair bit of non uniform noise/interference on my Superline phono stage.
I have been told to try shorting plugs in both of the two inputs on the back of the Superline. This should tell me if the noise is coming from the turntable.
Is an Earth from the Superline to the preamp of use ?? Think there is an Earth post on the NAC282
I used to hear voices from mine, in Russian mostly. I blamed the RB300 earthing arrangement at first and bought an Aro, no difference. I did find that a capacitance plug reduced the level, the 1nF nearly as much as the 10nF, I ended up using a 470pF plug as least detrimental to performance while still reducing the breakthrough. Then I bought a Fram lite and retired my Target rack, completely eliminated the problem, though I was somewhat surprised that it did.
Iâd tried earthing the Target rack and/or the pre amp earth post to no effect.
Are you using powerline adaptors for your internet by any chance?
Thankyou for your thoughts Yeti.
Currently I do not have any capacitance or resistance plugs in. Does it do any harm having them in if they are not strictly needed. The phono plugs are very tight and to get them in or out I have to put the rear transport screw in the prevent damage to the Superline.
I moved about 2 years ago and the house had no wired IT so as a temporary measure I added power line and that still exists in the room I have the set up in. Interesting you mention it. Think overall there are two left in the house now plus the main one plugged into the router.
I seem to remember @Richard.Dane mentioning there is a trick to fitting the plugs on the later Rega arms, something to do with a clamping collar you can loosen.
You need to really make sure the phono plugs are tightened down as tight as possible on the Next Gen RCA sockets on the Superline, otherwise you can get a poor contact and poor sound or noise as a consequence.
Check this first before adding any capacitance (if need be, 1nF should be enough).
Also be sure that the motor cable isnât running across or next to the phono leads. And make sure the Superline itself is poitioned so its not picking up any noise from nearby transformers.
FWIW, my Superline (connected to NAC552 and RP10) is completely silent - remarkably so, even with the volume turned up very high.
Unscrew the locking collars on the Rega Phono plugs first. That way they should go on the RCA sockets easily. Then tighten up. Otherwise you wonât get a good connection and you may even damage the Next Gen socket.
What RCA phonos does your Clearaudio have? You need to be careful here with the Superline as some donât make a good connection with the outer conductor of the Next Gen sockets, resulting in poor sound and excessive noise.
An easy way to check in the meantime is to temporarily use some 50 ohm BNC adaptors on the BNC input. Of course, these can create problems of their own, especially as they ageâŠ
I guess people are reluctant to remove fancy looking âAudiophileâ Phono Plugs from their deck/arm and replace them with âcrummy lookingâ BNCâsâŠ?
Was easier when even arms like my Linn Ittok (c. 1985) came with crummy Phono plugs on themâŠ!!
Unfortunately BNCs wonât always fit easily or well to some phono cables. The Next Gen RCAs that Naim use are much the best of their type (RCA Phono) and provided you have suitable plugs that can make a good contact then theyâre not a bad alternative to BNCs
