Good morning,
Is it possible to combine the Uniti Star with the Phono Stage Pre Amp?
Thanks and regards, Michael
Hi Michael, yes the Uniti Star has a couple of analogue inputs - one on a DIN and one on RCA Phonos. You could use either of these to connect up a Phono Stage. Note though that if you are looking at a Naim phono stage such as a Stageline or Superline, they will need their own power supply - the Uniti Star has no onboard dedicated supply to power them.
That’s what I’ve done. I’ve used both the RCA and DIN inputs, all fine.
I use a rega phono stage with my star and Linn into the phono sockets, very happy with it.
