Phono preamps and ideas
Hi all girls and boys. It has been discussed many times but, believe me, i have no time to read it all.
My chain is: Goldring Ethos on a Jelco 750d on a Linn Lp12 into a double Hicapped Nac 82 that drives a CB Nap 250 that powers a pair of SBLs. The actual pre is a prefix powered by a Supercap. I’m looking for something better than the prefix and they offered me the choice between a Gold Note Ph10 a Vertere Phono1 MK2 and a Hegel V10 at a good price. I have absolutely no chance for auditions and i can’t take the machines home for a test. Anybody have a similar system that can cast a light? Is there any other machine i should look for in your perspective?
Thanks a lot!
Of the three I’d pick a Vertere.
Actually a prefix is really good in a LP12, but Naim have better choice at a cost.
As prefix is old it might need service ?
Same for your LP12, its complicated to setup.
Hi Per! The lp12 is not a problem to maintain for me. Prefix and Supercap are more than 10 years old in the recapping area. I want to trade the Supercap for a new cartridge and get a pre phono that let me move in the settings possibilities. The Prefix is very good but haven’t been set to the goldring’s 100 ohm standard…..
As i said i really do not have any chance to listen to these or other machines before i buy.
Maybe just get it changed.?
Its a rather simple operation.
I’d put it on your preamp and change the hicaps to whatever..
you’re right but i want something new and more open on the SBLs front. I could ship the prefix and get it done but i would stuck on the Goldring. Two Hicaps for a Supercap but Supercap is more attractive on s/h market here as it is more rare. Do you think that the Vertere phono1 should fall nicely in my chain?
Prefix powered by a Supercap should be one of the best…
Recapping or Superline?
With a Supercap I’d seek out a Superline.
Same here in many occasions, you just have to take the chance and get the item home, try a few weeks, if no good, resell and take eventual loss.
Reason for pointing out Vertere is their kit always sound really good when listening.
I know Gold Note are popular among owners, I never heard them, and never heard a Hegel amp that I liked.
I had very good prices on the 3 machines used and ex demo. I have to add cables cost as mine disappeared during moving 4 years ago (i think i will contact Yannis Tomè for a solution). I do not hide the fact that i used AI to have suggestions but i think that the forum is the real experience library…….. I’ m talking to some shop owners but they tend to minimize the value of the gears i still own like my old 180, more hicaps, supercap, my old nait2. Even the cdx2 + psu doesn’t seem to move them so much……..
I’ll think more. Thanks a lot Per!
I have a Gold Note PH10 with the power supply. It is very simple to use with no dip switches it sounds great without the power supply and even better with it.
But it’s no more serviced….
As I understand, there’s no service “routine” for it, so no blanket component change-out regardless of whether good or bad. Instead, any components will be changed only if they are faulty.
Unfortunately, me old chicken this is true but can be repaired if needs be, and there is of course loads of great hifi stuff out there which similarly cannot be serviced but still performs well enough.
I have a Vertere Phono-1 LX which I upgraded from the L with upgrade scheme that Vertere offer. I think it’s a fine phono stage in both versions, and the prior version to the L, which was the MK-2. It’s very flexible with regards to settings, including high capacitance settings which I’ve found massively beneficial with my Hana ML. The downside is that the dip switches are on its underside which make changing the settings quite a lot less convenient than I’d imagine with the Gold Note.
I had the Vertere phonostage into 282 with one Hicap DR and Nap 250 DR and it sounded wonderful. Good cables also help with this combo. Beware that the Vertere RCA plugs are very close together. Certain cables with thick RCA connectors such as the van den Hul the Mountain do not fit…
Yes - that is what I came from. Prefix / olive supercap. Now going to Superline / supercap Dr … Hope that I like it … I love the prefix. :wink:
Hi Gianluigi, As someone who had recently had his Stageline S modified by his dealer to 100Ω for his AT-OC9ML/II, I can definitely understand why you might want to address this. The correct loading makes a world of difference for the better.
Beyond this, I once heard a system containing a Rega Ios, the forerunner of today’s Aura, and it was fantastic. People here speak very highly of the Aura, I notice.
But I have no experience of the Aura, so the best I can do is which you good luck in the search.
Cheers, Chris
Remember that Naim does use higher resistance in their Phonostages.
For a Linn Krystal ,Linn recommend 100 Ohm,
in a Naim Superline 576 Ohm is recommended for
Linn Krystal by Cymbiosis.
I think you may have missed my point. I have very little idea about which phonostages offer which loading resistances. My comment was that Golding Ethos and Naim Prefix S seem mismatched, and I would want to address that if they were mine as, indeed, @Gianluigi does.
