I’m currently using a Pure Sound P10 from my Project RPM9 turntable into my 202 and 200 combo, I love it. But…
Would a Stage line be a better match?
I don’t think so.
Probably depends on your cartridge but if you like what you have why change? Remember you’d be powering the Stageline off your 202. That said I had a Stageline before my Superline and I loved it. Could a dealer lend you one to try?
You will need a cartridge at first step
The P10 is an excellent stage - up there with the best for MM.
Totally agree with Richard
The P10 is a great phono stage
Only way you should leave it is for a MC phono stage
But don’t waste money on a MC cartridge with the pro-ject deck
Get a better deck first!
(Pictured below is my old P10… happy memories)
Better deck? thanks for that
Cartridge is a 120EB
I didn’t even want to be listening to vinyl until my uncle died and left me an old Akai Direct Drive and a load of Jazz at the start of the year. Since that I moved to a linn basik then to the rpm9 and developed an unhealthy addiction to buying Records, no way can afford to step up again.
Thanks for the advice re the phono stage though. I’ll stick with the P10
