Phonostage on SN3 - doesn’t like it!
Hi
I am trying to hook up a Gold Note PH10 and the sound just isn’t there - it’s barely audible.
The set up / selections look correct and I am using the AV input.
Any clues any one?
Have you tried a different input? Are you going in to the Supernait 3 via RCA Phono or DIN?
Hi Richard
Yes tried all the available inputs
Using RCA phono
Mark
Is the link plug fitted? (if not, power down first and leave a few moments before fitting it).
Otherwise, try a different set of interconnects, just in case the plugs are making a poor (or no) contact on the RCA sockets.
Ok thanks sorry what fo you mean by link plug?
Link plug in the back of the SN3
Is the Goldnote perhaps set to MM and do you have an MC system?
This might help it looks like the only outputs from it are line out balanced XLR
The two RCAs below are unbalanced outputs…no?
Indeed.
Have you set the front control panel on the ph10 to the correct output for your cartridge?
Dugh possibly
Seems very unclear :thinking:
Has he tried line inputs not the amp phonostage.
Hi all thanks for advice - yes had all settings correct but had to increase the load to 47k and it is sounding much better!
