I’m trying to play dsd 128 over my Naim a1 dac,
I’m using daphile as software in native stream mode. When play dsd 128 the track starts but no audio out. I’m using a gustard 32 usb to rca converter between my Mac and the dac
Any idea on what’s going on?
Ah, OK, well you will still need to check that the firmware is up to date as DSD capability was added during the DAC’s lifetime via a firmware update. Note that while the DAC is DSD128 capable, via s/pdif the limit is DSD64. Better here to convert to PCM in the source device.
