I have two Naim products - a Uniti Star and have recently bought a Muso Qb 2. I use the Muso to listen when I train in our back room and I used to play using Tidal. However, quite a few tracks I want to listen to are not on Tidal and I have copied them onto USB. I have a few questions
1 Is there any way to create a playlist which is a mix of streamed music (eg Tidal) and music on either usb or a ripped cd?
2 How do I select the play order from usb?
As you can tell I’m a novice on the tech side, but I will be very grateful for any suggestions and pointers. Thanks
