Hi,
I have a NAC 152XS and NAP180. I`m really stuck deciding what to upgrade next, do i pick a power supply? If so what’s the best option?
Hi,
I should imagine a used and serviced (non DR) HiCap would offer a very worthwhile improvement. Works wonders on a 202 so should do similar on a 152.
Don’t forget the FC2XS - you can use both power supply outputs to power the 152XS.
Very effective IME. And cheap too
One option might be to chop in your NAP180 for a NAP200DR. That way you get the DR tech into the preamp.
So, a change of power amp rather than the addition of a power supply.
I suspect very few here will have done it with the NAC152XS. You will have to try it and see what you think. Please report back.
Welcome btw!
C.
You don’t mention your source. An 82 with or without Hicap would be a cost effective upgrade…
I’d aim to get to 202/200 before adding power supplies. I’d swap the pre next.
I would just get a Hicap for now. Given that you asked what you should upgrade next, that will pave the way for a preamp upgrade. I would then hold out for a 282 or an 82, and keep the 180 until I could afford a 250.
Good morning all
Yes sorry, i should have mentioned that, source wise i mainly use a Pi with an allo-boss v1.2 DAC and an Audiolab 8000CDM/DAC combo. The Pi is surprisingly good. This of course is low end compared so many of you but for me it`s a good start.
I`ll look into those three options, FC2XS, Hicap and a 200DR.
Thank you Glad to be here sir!
I mentioned the NAP200DR because at the time of the NAC152XS’s launch, it was recommended that it be paired with either a NAP155XS or a NAP200. The NAP200DR didn’t exist at the time. But I don’t see why it shouldn’t have the same positive beneficial effects upon the NAC152XS that it reportedly has when powering other Naim preamps.
what speakers do you have?
At the moment a pair of B&W 707 S2`s, this is in the study so a small ish room.
I have the predecessor, the cm1. Nice speakers if bass ports are closed (bungs) and not too close to a wall.
They love power since they are inefficient loudspeakers.
