I have just received a couple of ex demo powerlines for Christmas and have noticed the actual cable seems different from one another. Did Naim change the flex the used at some point? @Richard.Dane you maybe able to help?
Popeye, sorry I can’t help as the Powerline arrived at the end of my time at the factory. I do, however have a few but, apart from minor diffegrences between pre-production and production examples, they are basically the same. Possibly one for Naim or hopefully someone else here can advise.
Do they have serial numbers ?
I have one without a serial number and the cable is slightly different to my other 4 power lines.
I thought it might be a early version
@popeye,…This below I wrote in another thread.
Good to know,.if you’re going to compare these two Powerline’s in the same device.
"We burn-in these new powercables in this way in 300 hours,.after that,they get to sit in the music-system for four days before we listen seriously.
But even if a powercable is burn-in,.and you have had it out of the system just a little while.
There is a difference in soundquality,.if you listen right after you put it in the system,.and after 30-40 minutes.
That difference increases even more after another hour.
This is important to know about,.if you shall test different powercables."
