Powerline Lite on olive 140/hc - a worthwhile investment?
I have the original mains cables on my olive 140 and hc. Has anyone experience/ of upgrading to powerline lite on these units? Was it worth doing? Powerlines would definately be out of my budget but the lites are interesting?
If you can buy them second-hand, you’ll be able to try them and if necessary move them on with next to no loss.
I found a PLL very worthwhile on a Hicap.
Well I guess that’s as good a place to start as any ! I’ll look out for a second hand one to try - any advice as to how to distinguish genuine from fake?
I wouldn’t worry about fakes. It’s just a standard Naim mains cable with a lower cost version of the Power-Line mains plug fitted.
Easily found pre-loved in the usual places for around £50 - 60.
