So I’m intending on buying a powerline for my Nova, looking for anyone with experience for some input.
Also…and this is in my head somewhere. I have an extension lead (not a cheap Asda job…but not a new power source by any stretch…was about 60 quid)
To get the best out of the powerline, should I aim to plug it in the wall, or will it do it’s job from the power out the extension cable (in reality that’s where I will have to plug it)
I’ve added a Powerline to my Nova and it was worthwhile, more solidity, cohesion and control.
If it won’t reach your wall socket you’d probably need to add a decent hi-fi power block and mains lead back to the wall, which will improve things further as well.
I’m in New Zealand, so our options might be different. I use an Isotek power block and mains leads back to the wall plug, then a Powerline from the power block to my Nova.
With the RA powerbar you will need another cable to the wall, as it doesn’t have a captive one.
The powerline doesn’t have any esoteric cable within, just decent quality. The connections being its strongest point.
Using a powerbar with the standard cable that came with the Nova, to connect to the wall. Then a powerline connected to the powerbar to the Nova should be worthwhile. Better still to get two powerlines.
