Presto app
Is anyone else having issues with the Presto streaming app? Mine keeps freezing on my iPad such that, for instance, the previous album insists on being played over any new choices. The only answer I seem to have is to delete the app frequently and re-install.
On its own, Presto app works fine for me. Not used yet it with my QB2 as I’m still waiting for the firmware update from Naim. Presto on my Linn streamer works fine, but it’s a different implementation as it’s controlled directly within the Linn app and not from the Presto app.
Roger
Yes. I am having freezing symptoms. Also when I open the Presto app on my iPad and MacBook the Naim Uniti Atom starts playing the previously played album on the Presto app. I try to change the device in settings or control centre but it is frozen. I have reinstalled the app to no good. The Naim changes input even when another input is active.
I am sort of glad that it is not just me then! I have referred the issue to the technical team at Presto but as yet they have not been able to work out why this is happening or provide a solution.
I’ve just signed up following the Mu-so firmware upgrade and I find that Presto stops streaming every 20 minutes or so. The app becomes unresponsive. A reboot sometimes clears it but I may have to play a new album and then go back to the stalled item which then restarts.
Presto are still trying to find an answer to the issues I am experiencing with its app.
I’ve posted a few thoughts on Presto in the Music section
Ok thx Richard. I will try and locate. All sorts of Presto issues with my new NDX2 connection.
Up to now, I’ve used Presto on my Linn streamer where it’s integrated into their app, but to test it on my QB2 I’ve just streamed an album of Scarlatti sonatas. The album is over 70 minutes long and it streamed the whole way through, controlled through an iPad, without freezing. Could the problems be something to do with the Connect implementation I wonder?
Roger
I was watching what happened on the app on my MacBook.
As each track plays it changes colour. After a while this stops but new tracks continue to be played. Then the stream cuts out. On rebooting the previous, played tracks run at speed (without playing) as the app ‘catches up’.
Could be. The fix suggested by Presto (turn off Private email address) hasn’t worked.
Tidal Connect runs without any problems.
