ProAc D2R to replace my Tablette 10 Signature speakers
Hello,
I’m thinking about possibly switching to this model instead of my Tablette 10 Signature speakers.
To get a little more bass (but not too much).
My room is 19 m² (in an apartment, so I turn up the volume, but not like a maniac).
Does anyone know these speakers?
I was also considering the D20R, but my wife isn’t too keen on their look, and I’m a little worried they might have too much bass.
Do you have any thoughts to share about these models?
P.S.: For now, I’m still really happy with my current speakers—they pack a lot of punch for such small boxes.
I mainly listen to ’80s synth-pop, but also quite a bit of classical and jazz—mostly piano for those last two genres.
P.P.S.: I love the latest liquidambar veneer
Lovely speakers! Have you considered the DB1”s s well, as they have more bass than the Tablette 10”s and can be supplied with the dome tweeter if you’re happy with its tonal balance. The ribbon tweeter produces a very different sound which you may/may not prefer. Both have ports which means placement away from the wall is almost mandatory if you are to avoid bass boom. Also, don’t assume that front v rear port will fit your room better, as it really depends. A home dem is pretty much essential. Another option I have found works, particularly in awkward rooms, is to add a subwoofer, like the REL T5X. Enjoy your auditioning and take your time to make the right choice.
Agree re port position .. don’t think it affects room placement much .. my system 2 moved from Tab 50 (rear ports) to D2 (dome) - front ports .. richer, fuller sound, more bass, yes .. but those little tabs had a certain magic of their own. Also mine were fed by ND5XS/NDAC/82/HCDR/180 .. so make sure your front end is up to it first.
As you can see in my profile, they’ll be powered by a NOVA POWER EDITION, which I think will be able to drive them well.
I’ll take a look at the DB1s, but you’re right—there’s also the D2D model with the silk dome tweeter (which I really like on my T10 Signature speakers).
I have the D2R’s with a 222/250 set up and they are just magnificent speakers. I would strongly advise getting the ribbon tweeters rather than dome - they are very, very special. D20R’s put out an awful lot of bass so take care. If you want something a bit smaller then have a look at the new DB1R’s which also have a ribbon
What kind of stands do you use for your D2R?
EDIT : ok, Custom Design RS302 stands
Partington Dreadnoughts on my D2D … (predate the Ribbons btw which I haven’t heard … and most seem to prefer the latter)
The only really useful information anyone could give you would be if they have compared both of those speakers themselves. Even then you really have to hear yourself to know if they are out for you, as one person’s perfect sounding speaker someone else might feel is awful sounding.
Thank you for your feedback.
Yes, indeed—if anyone has had the chance to listen to the D2/D and D2/R, could you please describe in a few lines the differences in sound between the silk dome and the ribbon driver?
I think the silk dome is the same one that’s in your Tab 10’s. I could spend ages trying to describe the sound of the ribbons but in the end you just need to listen. They are remarkable and I could not return to domes again
I’ve owned numerous ProAc’s .From the original Response 2 through the current D48R. The ribbon is the one to get. The D2R in that new liquid amber are beautiful. Just get the right stands and proper setup and away you go on a magic carpet ride! I really regret having to sell my D48R’s but I had no choice. Although I do enjoy my ATC SCM 40A :grinning_face:
A few replies from the period I was changing my Tab10S for the D2Rs:
The ribbons are much more transparent and openly detailed but they are also brighter sounding, albeit not in a harsh way. In my experience I think the domes sound stage is a bit more natural and wider. For years I preferred the dome over the ribbon but more recently the ribbon, albeit on the D20R’s, won me over. I don’t know if my tastes changed or whether Proac developed the tweeter further. Either way you need to dem, especially as you’re using a class-d Naim amp in your particular Nova. Naim/Proac always worked well together but I have no experience of this particular version of the Nova.
@anon22505844 how about the new AlChris TX-5 RS due early next year ?
Ribbon from the awesome TX-9. Highly recommended and updated mid/bass driver.
Hi @The_Lecht_Rocks,
thanks for the suggestion.
On paper, it sounds like an interesting option, but…
I’ve never listened to this brand, unlike ProAc.
And… since I live in France, I don’t know where I could listen to them or even buy them.
That’s very unfortunate then.
The D2R will be a great speaker but less so than the TX-5 at twice the TX-5 pricing….
Good luck regardless..
I’d be interested it what you decide to do as I have signature 10s and looking for a little bit more base. I love the 10s so need to be sure of an improvement before changing
I’m biased but the D2Rs are perfect. Not too big, not too small(the db1 didn’t have the ribbon tweeter until recently).
