Blah! How do you cancel a post?
The other “problem” with just a dealer’s thinking is even if price points are similar, one brand may have a higher profit margin or an incentive. I also had to buy" blind " several years ago but found many different reviews and such before making a final decision. I ended up with Harbeth M30.1 and have been pleased with them.Comparisons are less likely to be found, but by reading enough different opinions and reviews hopefully you can find the differences and decide which works best. I’m not too familiar with either, but also recognise that some types generally have more or less interaction with rooms. I purposely did not want to chance rear ported, although I am a fan of Dynaudio, I felt it was too much “risk” for the room.
