Before I went on holiday I shut down and unplugged my 332/333/250, in case there was a storm.
I have now plugged everything back in and started everything up, but no sound. I only stream via Tidal (which works well on my phone).
I remember when I first got the system I had a similar problem, which turned out to be that I had not set the ‘streamer output channel’ or something along those lines, and I was told how to fix this but I’ve now forgotten the process and I suspect this might be the problem. IIRC it had to be set to ‘channel’ 8 or 9… can’t remember.
I have gone over the other setting, which I think are correct (streamer to pre via DIN), see below:
Sorry I’m not familiar with the NC stuff but doesn’t the Preamp streamer input which is set to 1 (stream) and then the next screen shot of Preamp 1 (Stream) - Off indicate a possible cause of the problem as in although it looks like the correct input is selected it looks likes it status is off, can that be toggled on On?
Apologies if this is wide of the mark but just stood out to me.
I stripped the system down, turned it all around so the equipment is facing front, plugged it all back together and plugged it in again, and it is now working.
I did check with the dealer to see what the previous procedure was and he explained that I need to press and hold the Stream button, which puts it in set up mode, I then use the volume button to dial round to number 7, which is the number of the DIN socket I used on the pre-amp to connect to the streamer; then press and hold the Stream button again to ‘assign’ that socket to the streamer, then it’s done.
However, I did not need to do that this time, just strip it down and back up again
The settings you refer to above are the same, I agree it looks a bit odd, but it works and is lovely.
I am glad I now know the streamer assignment process as it is possible I need it again, but this problem was essentially a version of switch it off and on again!
My Densen CD player (still going since purchase in 1992 I think) likes to pull the silent treatment every now and then, it takes a proper power down and power lead out and 15 mins and then the drama of power up to see if she is in a better mood.
