I recently got a new window 11 computer and am unable to see the Unitiserve on windows explorer network folder - can see a NAS still but I use the US for my music sreaming. I therefore cant copy and paste the new album to the US downloads folder
Tried google but to no availe so have to use a USB in the NDS to play this new album
Oviously not satisfactory
US has latest (albeit old) updates
Upgrading to Uniticore expensive and hopefully not needed
How old exactly? The latest is 1.7c but for some reason Naim like to keep it well hidden and mostly refer only to the previous version 1.7b on their website.
Chances are this will not solve your problem, but still something to be aware of if you’re not already.
I had a similar problem about 18 months ago with Unitiserve, running the latest firmware. The Unitiserve worked fine, but my Mac just could not see it on the network, and neither could @ newly purchased UnitiCore. Naim’s software director kindly logged in remotely, but was unable to fix it after an hour and half of trying.
I was trying to move music from Unitiserve to UnitiCore, for which we found a work around using a Unitiserve back up.
The original problem was never fixed and remains a mystery, although it was suspected to something related to SMB1 and access permissions.
The Discourse software takes off the first \ as it regards it as a system character. So if you want to show two back slashes, you actually have to type three of them, which is what I am about to do \\
Just to be clear, the UnitiCore functions perfectly. It’s just that neither it or the Mac can see the Unitiserve on the network.
The Unitiserve also functions perfectly, but since the Mac can’t see it on the network, it’s not possible to add Hi Res music to the downloads folder. In all other respects it’s fine, it rips CDs, and sends music to my streamer.
