Problems with my Nova
Up until about month ago my new Nova was singing along perfectly without any problems, however now it’s often impossible to find on my network (it was wired and I’ve since gone to wireless to see if that helped) when I do manage to connect it after multiple attempts it skips tracks or just drops out when streaming Qobuz. I have 4 other Naim devices that work perfectly on the same network all wired. When it drops out when streaming and I often lose control of the front panel and app. It sometimes shows I’m playing the previous album while actually playing the next and won’t even allow me to play to a cd player that’s connected.
I’ve just carried out a factory reset and it’s currently working but it’s done this before.
Spoke to Harry my dealer several times and thankfully he’s offered a replacement while they investigate.
Has anyone else had or having similar issues.
No I’ve not experienced this but similar. Tough one but this is what I’d try if it happens again. Power off the Nova. Power off any routers or switches. Wait half an hour. Power up the routers etc. Once you see a wifi network back and running try a wired connection to the Nova. Power it up. Hopefully this works.
Done all that even got my IT guy to reboot all the network and performed a factory reset on the Nova. I believe there’s something wrong with the network card/circuit, my network is fast (550+). None of my other Naim devices are having any issues
Sounds like you are right then.
This usually works for me, when my nova is losing the wireless
