Since the last update of may 20th, the remote have difficulty to ajusted the sound level up or down. If I press up, it will up and down. Most of the time I need to use the app.
Anyone have the same problem.
I presume you changed the batteries
Have you tried a restart of the Nova?
Yes. No change
Yes, no changes. Could it be because I use also audirvana app for mqa file.
