I would enjoy it on its own for a bit before considering adding a power supply. It’s extremely capable on its own, but my own feeling is that the power supply that’s really worthwhile with the Naim DAC is the 555PS.
A HICAP would probably be great, a HICAP DR better still. However, if it’s past its best and in need of a service then this can dramatically lower performance making things sound slow, laboured and engaging.
Better than a Hicap would mean a Supercap. It would certainly work, but at that price you might want to reconsider whether a Supernait is the best option for you compared to separates.
Perhaps trade in the Nait, Hicap and Stageline for a SN3. Then you won’t be without music.
You can always add a HicapDR later, almost certainly best to buy rather than upgrade an old one to DR which is prohibitively expensive.
The benefits of a Hicap on a Supernait are subjective, some prefer it, others do not. If you like what it does I’m sure an older serviced Hicap would be fine, but a HicapDR would be better. Still, you’ll never know what suits your personal taste unless you listen to it.
Yeah I’m finally getting an nDAC after 5 years, and I’ve used a Rega DAC. My fear is I spent a lot of money and won’t be able to hear improvement…hehe.
I’ve heard all these horror stories about people that upgraded multiple times and never found a sound as sweet as their first. This XS setup has been marvelous.
Well, you’re in luck, as some here reckon the earlier 555PS (not DR) is optimal with the Naim DAC, so secondhand is possibly the smart way to go here, and you save a bundle too.
Yes, it’s a lot of money by any standards. As Richard says, the non-DR version is preferred by some, possibly because this was the current model when the NDAC was developed.
In the meantime I think the bare NDAC still sounds great, I could happily live with it without a PSU upgrade.
The low end has improved substantially and instruments are more real sounding, also the soundstage has more depth and easier to position the musicians.
Bass notes are longer, and there is some new high end clarity and “effects” that gleam in your ear that I never heard before in the songs.
It’s a solid change, and also the real high notes are more polished and not as painful on the ear.
