Hello MichaelB,
Aha, I understand.
True, a managed, and especially a used managed switch, is IMHO not the solution for data-integrity on your LAN. Resetting those managed switches is not easy, and leave them managed as they are will cause new, other for the user unknow issues on the LAN.
Maybe a bit of a semantic discussion, but a manageable switch is ALWAYS managed, that’s why it is called a managed switch. When you leave it in its originale state, it will still be a managed switch, managed by its former owner(s) or by the Brand who sold it. Switches come in a lot of tastes, and this has a reason! They are designed for very special tasks, keep that in mind.
So, I only buy new, unmanageable switches. I’ve got two know, and is it’s a great improvement on my LAN. Not only for music streams, but also for IP TV and the WIFI connections.
If this tweak may not help boosting up your performance on your LAN, it may be due to the fact that the ROUTER of your ISP understands only one speed. So it is paramount to connect only the ROUTER whit the switch, and leave the other RJ45-connections unused. No other connection is allowed, only for a second/third and so on, switch.
Now you are sure that your LAN will be provided with the highest speed possible, whit the best data-integrity possible on your LAN
Another misunderstanding I encounter in various blogs and posts is about TCP. TCP can provide data transport with the best data-integrity possible, but that’s only a possibility to use TCP. TCP can al so be used to send data back to the sender, not to check the data-integrity, but to look, for example, into your computer, use your music files to stream them to other members, like with P2P connections (the early SPOTIFY method). Hence, with TCP it is still possible to loose a lot of frames on the way to your DAC, and there is no guaranty that TCP always is providing a lossless format. With streaming it will be never lossless. I realise, it is a bold statement; But, it’s almost impossible due to the fact streams take place in real-time-domain-conditions. TCP is not developed for real-time-domain data-streams. So I am convinced that this is the main reason why people experience difference in sound, when altering the LAN-connections.
Enjoy listening
