The remote works, and controls the unit, but the volume + - and mute buttons do nothing. Should they?
The power plug on the rear is rather loose, which is not something I am accustomed to. It’s not ready to fall out, but it jiggles rather easily. Should it be like this?
The power iec power cord should wiggle a little, its designed that way to minimise vibration etc . As for the volume setting on the remote perhaps some one else can advise.
No Naim pre amp or Naim integrated amp. Is that what the vol/mute is for? I thought it weird that those would be controlling the CD player itself, but stranger things have happened…
It’s so that if you have a full Naim system, you only need one remote. The CD player gives a fixed output, varied by the pre amp for the power amp then speakers.
For those of us with multiple Naim components, we end up with multiple remotes that are redundant - because the remotes are designed for the entire Naim system (to generalize).
