I have seen others with somewhat similar experiences. After the 2.1.10 update with the new internet radio. Streaming radio overall works as expected.
However over the last days it seems that streaming radio too often stops, the qb loses connection both to the stream and the app.
I need to power down and restart the qb. This solves the problem but is a bit annoying, in the middle of my morning what has happened in the mad world update.
Usaully I stream Danish dr p1 or bbc worldservice but the channel does not seem to be the problem.
Hi,
I have been suffering the same problem with my 1st gen QB. The HLS BBC HD streams seem more susceptible than Radio Paradise or lower bit rate streams such as LBC. The only reliable way I have found to get a consistent connection in the morning is to perform a full shutdown the previous night, rather than just putting the Muso into standby. It would be useful if Naim could give us some guidance to help debugging the problem.
Regards Dave
