The Naim logo and top control on my Qb(1) has started flashing. Any ideas?
Lindsay
Lindsay
First try a power off reset. If that doesn’t work then there is a small led on the back that will be flashing a colour. Look in the online manual on the Naim web site and you will see a guide to what the colours mean.
In my experience, problems with my QB1 have always been network related as the wifi module is crap, it is almost certainly the weakest wifi client you own so everything else working means nothing in terms of QB1 trouble shooting.
Thank you, inexplicably this morning it’s working normally.
Lindsay
It’s those gremlins.
Remember that Julian Vereker started with a Syncholight.
