Apparently a whole new interface and some new features from update available 00:00 hours French time…
What is the version number of the new release? I have 8.2.0 and don’t know if it is the latest now.
Thanks. I think I have an older version (8.2.0) so I will try for the update tomorrow.
There is no update for the desktop app. It’s still at 8.2.0. I never use the iPhone app.
There was a big update a week ago, is this another one?
This one is for the play screen on the app. Looks a bit different and depending on which button you press you can get more info., or lyrics, or suggested other music in explore based on now playing…The play bar stays on the screen too.
Depends on how you’ve enabled the app through your streamer…Fixed volume, or otherwise…
I’m rather enjoying the new features - worthwhile update. Shall I start a thread that runs into thousands of posts asking if there is a change to the sound quality?
NNNOOOOOO, for God’s sake, NNNOOOOOOOOO
Liking the new look on my iPad.
Lolz!
I can’t find the volume control in the latest app - for my Atom HE. Have you found it?
Don’t use it in App, so haven’t looked. I control volume through the amps only…
Ok, thanks. I could control the Naim with the previous app using Connect, but this time the volume control is eluding me.
i don’t think there is a control in the app but the volume control on the side of my tablet works on my nsc 222
