Hello, I notice that the Qobuz streaming doesn’t work from the naim app anymore since yesterday (I didn’t check during the week)
It works from the Qobuz through Chomecast, but not inside the naim app.
Do you have the same issue ?
Best regards
Bertrand ROUSSEL
I don’t use Qobuz so can’t answer your question. But have you tried a power off restart of your Naim streamer and a restart of the Naim app? That may fix it for you.
Best
Working OK here.
Roger
Working for me.
Working OK on my NDX2 perhaps a re- boot?
Working on my Atom!
Qobuz is working fine here in Seattle, listening to Patrcia Barber’s ‘Companion’ at this time…
Restart your router, wait, then your Ndx2 and install again the Naim app.
Should work.
Delete the Naim app, re-start your phone/tablet and re-install the Naim app…works for me
Thanks, it was the solution !
