Anyone have any idea if it’s possible to inadvertently buy something twice - I only ask as I often buy lots in promos and occasionally forget I’ve bought something I’ve ‘parked’ to listen to later!
Would you get a warning if something is already purchased, as it certainly doesn’t say so on on a particular album/work’s page?
I had it recently and Qobuz prevents you from buying it twice - which is a great quality assurance. I guess this doesn’t work if they have two separate line items and you made the mistake of selecting the one first and the other second. But this seldomly happens that they have two linitems for the same album, so change is almost zero of you going wrong.
