You can also try mconnect. It shoud play gapless.
For me best way is using bubble upnp server and Kazoo with my 272. Work gapless and transcode to wav on my qnap.
How many times do I have to repeat myself. This is all about the new streamers not legacy, None of the old ways work at all for getting Gapless via ChromeCast or UPnP
for Qobuz.
Legacy kit that just happens to do what youâd expect it to do!
Over the past day or so I have revisited the Qobuz desktop app on a Mac rather than going to Audirvana+ for Qobuz over UPnP, or accessing it via a proxy server. Selecting the Beta DNLA/UPnP for audio output to a new Naim streamer, Iâm finding the SQ to be very good, much better than I expected from the stand alone app. Except for one thing, that is, at the end of a song/movement, the music often stops instead of moving on to the next piece in the play queue. When this happens the UPnP connection is lost and has to be selected to restart the play list. Is anyone else experiencing this?
Yep did it for me all the time.
Reverting once again to type, the answer is perhaps Roon when it acquires Qobuz support which if rumours are correct will be while Teresa May is still Prime Minister. This will give full gapless on all new Uniti / ND machines just like it does with Tidal.
.sjb
But that adds the cost of a Roon subscription to the Qobuz subscription making it a very expensive option. If, like me, you see no real benefit to using Roon that makes this a non starter.
Yes, just not reliable enough to use to my Nova - ok itâs in beta but my hopes arenât high. Airplay works well again, but of course you only get CD quality with that.
In fact the whole Desktop app has been a bit of a pain - it lost loads of downloads once for me during an upgrade.
Iâm eagerly awaiting the Qobuz integration, letâs hope it actually comes about.
My only issue with Roon is that Iâd like to be able to have more than 1 Core installation as I boot different drives on my Mac Mini and itâs annoying that you canât install several times with a single instance of Core being available at aby one time. It would help if they offered additional core licenses at a discount but they donât AFAICS.
We also have the problem where some people actually think Roon quality is not as good as streaming from a NAS or local files. I like Roon a lot but don;t use it as often as I should perhaps.
In the Naim universe a Roon subscription is relatively inexpensive, a lifetime subscription for less than a powerline. But if itâs not for you, itâs not for you. It might be an option for others.
.sjb
Yes there is a workaround for Android devices.
The there are two API that the people who write the apps can use to connect via Chromecast.
The first is very simple and that is the one they use, but it doesnât support gapless - itâs not the fault of Google (/chromecast) but the intentional choice of the app writers.
The second is more complicated to implement (so they donât use it) but it does support gapless.
The work around is to cast the screen on the android device rather than just casting from the app.
I think that effectively doubling the price of the Qobuz subscription makes it a non starter as itâs really not all that different to Tidal - not worth twice the price in any universe. I accept itâs not âall that muchâ in the Naim universe, but it shouldnât be necessary- I, and Iâm sure others, donât care who is at fault (if anyone), but just want it to work as Tidal does and without additional products having to be obtained.
If youâre going to make other use of Roon then obviously thatâs a different value proposition* but using Roon exclusively as a method to use Qobuz isnât really the way forward, whatever I think of Roon and itâs use (or lack of) to me; Iâm aware there are many who think itâs marvelous and Iâd not argue with their choice, Iâm happy with that, weâre not all the same. And Qobuz works properly for you too ![]()
*10 bulldroppings bingo points for that one ?
Well, this is interesting.
Qobuz integration with Roon - great bonus for me as an existing Roon user.
The really interesting thing is that I played a gapless album and it played gapless - great the Roon proprietary RAAT engine solves the issue I concluded, then realised my Nova appears twice in the Zones - it was actually playing back via Google Cast not the RAAT engine which also gave me gapless.
So, a properly written app can stream gapless via Chromecast built-in on a Mac - question is whether or not Qobuz have the ability to implement it in their iOS app, which they have failed to do to date.
Yes ChromeCast is quite capable of gapless, Google Play manages it. Roon worked very closely with Google on implementing ChromeCast support as endpoints, to get the best SQ out of it and as you have discovered gapless.
The frustration for many is that the older streamers managed gapless playback quite happily using other older protocols whereas the new streamers have changed something and no longer can with those older methods (they never had Chromecast either), unless playing via the Naim app to access local/NAS storage.
So is there something Naim can revert to in a future update for the newer streamers/Uniti series to allow systems to play gapless without all the hoops or using Roon, which I like, but wonât be to everyoneâs taste.
Thatâs up to them, I guess. But it doesnât seem high on the agenda
No it certainly doesnât - I think it would be nice to have some clarification from Naim on this - if Chromecast built-in gapless support requires specific methods for it to work it would be useful to know which apps/companies support this kind of playback, and we could then individually request this sort of support from Qobuz etc if they donât currently support it.
The specs for the new streamers/Unitis state gapless playback for all formats, but Iâm not sure thatâs accurate if there are qualifying factors.
Cavet is Gapless ( only via Naim App) why would anyone want to use something else than our lovely app.
You wonder if theyâre missing the fact that itâs fine for services directly accessed from the Naim app, but not for those provided by 3rd party âhelperâ apps using Chromecast.
Nobody from Naim around here who can comment on all this?
What about a possible integration of Qobuz in Naim streamers via a firmware update?
Is there any hope of solving in a not too remote future the gapless playback issue when streaming Qobuz via the Google Cast protocol (ChromeCast Built-In)?
