Qobuz Metadata
Wondered if anyone else has issues
I downloaded 2 albums a last week, no metadata on either, so had to manually type it all in, a drag!
I tried Qobuz help, got nowhere, I have eMailed Qobuz support, but have not yet received a reply
I do have a few more lined up, but do not wish to download until problem resolved
Thanks for any suggestions
Qobuz is not my usual source of downloads but I did buy an album last week and it came with metadata. I did use the Qobuz downloader app.
Mind you I always edit the metadata using Metadatics, before saving to my NASs.
Roger
I’ve downloaded hundreds from Qobuz but never had one with no metadata. Like @PeakMan I also always edit the metadata with Metadatics.
Which were the albums?
Same here no metadata issues, purchased approx 12 albums in past few weeks and all good. Did you try to re download?
No problem here either.
If you download a lot of music it may be worth getting Mp3tag that supports "Importing metadata from online Tag Sources
Mp3tag for Mac/PC supports metadata and cover import from Discogs, MusicBrainz and other custom sources"
There is a 7 Day free trial.
Thank you all for your replies.
I used the Qobuz Downloader app - tried two or three times - no metadata
I will investigate the editors suggested, and hope Qobuz come up with an answer
Thanks again
