So now it’s here, is there a decent way to painlessly migrate to test it out? I’ve previously used tunemymusic to transition between Spotify, Deezer and Tidal. But there doesn’t seem to be a Qobuz option.
Any suggestions how to most efficiently try out Qobuz?
Qobuz like most music services have a free trial period. So sign up whilst keeping your existing service.
Then use a service like soundiiz ( https://soundiiz.com/ ) to migrate your playlists from your old service to your new. Some albums and tracks might not show up because of the difference in catalog coverage… but it gets you going.
I wouldn’t say it’s very poor outside classical and jazz.
Pretty much most of my listening is on there, but I think they don’t do as much electronic stuff
I have been using Qobuz for the last three weeks although not with a Naim streamer. I have used it on my Astell & Kern DAP which is the Android version and I have also loaded it on to my iphone X. I have really tried very hard to like it but, unfortunately, my experiences with Qobuz have been similar to those of @obsydian.
There was initially quite a bad bug on the Android version which does seem to have been rectified now. But it still takes a long time on both the Android and iOS versions for the list of favourites to be completely displayed and means on the iOS version scrolling right to the end of the list of 600+ albums before it will display the full list. On the Android version, I have waited about 5 minutes and then tabbed between various menu options before returning to the Favourites list when it eventually appears. I’m not sure if it’s just the passing of time or switching between the different tabs which actually solves the problem. Qobuz support isn’t great and after a longish wait usually just give one line generic answers like ‘try reloading’ or ‘wait for next release’.
However, for me the real killer is the lack of content for the type of music I listen to, mainly smaller label new releases, compared to Tidal. This makes it unsuitable for me as a discovery tool.
Sound quality wise on the Astell & Kern I would say the difference is small and not always in favour of Qobuz. Athough arguably slightly cleaner and more detailed, I would say it’s a leaner sound which doesn’t always work well in my situation and I often prefer the more full-bodied sound of Tidal for many albums.
Once I have my proper home system set up with probably either a Naim or Auralic streamer I will try it again. But for now, I’m sticking with Tidal. The difference is reduced slightly fo me as well by MQA processing being available on the Astell & Kern and only paying €19.99 instead of £19.99 for Tidal for historic reasons.
I think it’s fair to say though that most Naim streamer users seem to prefer Qobuz to Tidal.
