How do I go about streaming Qobuz in New Zealand? I cannot find a link to Qobuz on the Naim App! Do I have to create a Qobuz account first?
Appreciate any advice. Kind regards
If your system still comprises a 272 per your profile, then qobuz is not natively supported.
You can add an external streamer that does support qobuz, then connect to a digital input on the 272.
Exactly that Robert. I have a 273. Thanks.
The solution for you probably splits into 2 options:
Hardware - add another streamer, this can be a pure transport ie no dac as you will plug it into the back of the 272. Examples are; wiim, eversolo, limetree bridge.
Software - bubble upnp and I think there’s a solution using mconnect … these present qobuz (for example) as a upnp stream on your network which the 272 can see and play.
There will be several threads on this forum, there’s a comprehensive one ref bubble, search for iirc bubble and nds or ndx (or probably 272)
Maybe here? NDS - Setting up BubbleUPnP Server/Audirvana
Thanks Robert. I’ll investigate what’s available here. Much appreciated.
