Are you 100% positive your comparing exactly the same version of the release. Qobuz like tidal often have several versions. Can’t see if it’s exactly the same how it could sound any difference except from cognitive bias.
What would be labelled ‘My Favourites’ in Qobuz app seems to be My Albums in the Naim app, so I assume you are playing something from there and comparing with an item from a fresh search of Qobuz and choosing the same track?
Thanks. I only have a couple of tracks in playlists but can’t hear any difference this morning, though everything is sounding a bit flat for some reason.
I control qobuz from my iPhone and the sound is clearly superior when hold the phone in my right hand and hit the buttons with my left. Even though I am right handed.
