I have a naim nova all in one and I stream qobuz.
The nova is wired connected to the router. I select the music on my iPad.
I don’t understand how this works. Does the naim connect to qobuz or does the iPad download the music and send this to the naim?
I want to make sure I get the highest quality
Does someone has the answer/
HENK1.
The Nova streams the music from Qobuz. Your iPad is only used for control and is not part of the reproduction chain.
Roger
Thanks for your reply!
henk
Your question is incomplete. If you are streaming via the Qobuz app then you are restricted to Low Res only (connection to Nova via Bluetooth/Wi-Fi). In order to listen to Qobuz Hi-Res you have to be accessing your Qobuz account via the Naim App, as there is no Qobuz equivalent of Tidal Connect (sadly).
