Qobuz
Suddenly, my Albums list in the NAIM app has disappeared and nothing is accessible in the Qobuz app.
Anybody else getting this?
Mine looks OK.
All good here too. Sounds like you’ve been universally logged out?
Seems something to do with the last firmware upgrade (sigh).
Hi Mike, afaik that Connect Beta has now become the regular Beta. Are you in the regular beta program for Qobuz as well? If not, then you could try to apply for that as it seems that you have a beta app?
Maybe I’m wrong, but just trying to figure out why you get this.
I’ve no idea what any of it means. The new “straight to streamer from the Qobuz app” functionality worked (more or less) O.K. for a while, but now this.
shrugs
It’s something to do with your qobuz account, I suggest you login to their website and check your account settings.
As Qobuz Connect has been launched, it’s not necessary to use beta apps. You can just the regular release Qobuz and Naim apps.
Turns out, it doesn’t like being run behind a VPN.
That makes sense. Qobuz can’t know your streamer’s IP address to send the music to if you are behind a VPN.
Was just about to mention the VPN.
