Question for Hicap-DR owners (dimensions)
I know the HCDR is 317mm deep. But, that doesn’t tell me how far the feet are spaced. Will it fit on a shelf 295mm deep? It will stick out a bit, but that doesn’t bother me. I just wonder if the 4 feet will fit on a 295mm deep shelf?
I absolutely think so, but will let current HCDR owners confirm.
Yes, it will fit.
Thank you Mike! It looks like I am saving up for a Hicap.
You can just see the foot in this photo:
Is the shelf tight uo to the wall behind? You’ll need to allow space for the cables sticking out of the back, not just the box itself.
Yes, there is enough space for the cables.
