bruss
1
When using the control app on an ipad. If you select your streaming source and start play, if you then close the app does play stop?
When you stop play, put the ndx2 in to standby mode and then later turn back on from standby mode, does the same input stream show?
Tia
Closing the app doesn’t stop play.
When the app is reopened it shows the home screen rather than the last used input, but the previous play queue is still there.
bruss
3
Thanks. Just comparing apps between transports for ease of us.
system
Closed
4
