Hi,
I’ve just received a mail about an upgrade to the 1st generation muso/muso Qb to allow continued support of Tidal. Can anyone tell me if it contains the fix that prevents Roon from starting the muso at full volume over AirPlay?
Aidan
Hi,
Aidan
I thought that was long since fixed… let me check in morning
Thanks. I’m running a ‘special’ version of the software because of this bug, which is immensely irritating to my neighbours.
Hi @franchiser
Yes it does. It incorporates the mods in the 1.8.11 version for Roon customerss.
Best wishes
Steve Harris
Software Director
Naim Audio Ltd.
Thanks very much Steve et al.
Both old musos updated successfully.
Aidan
