If I obtain an Ultrafast service from Sky (145mbps) eg , will I be able to use my BT whole home mesh discs with the sky router?
I have bt ultrafast and discs purchased later, and ad long as you can get into the sky router and turn off Wi-Fi then yes you can. Other wise you’ll have two Wi-Fi zones which I guess won’t harm as long as you know which device is on which!
Thanks @Hifi-dog: your advice concurs with what I have eventually found via my net research, after wading through much gibberish.
