Hi.
I have a Moth record cleaning machine which I hardly ever use due to the noise and the heat it generates in my small, 3M*2M, office where it and my lp collection are stored.
So I was wondering if anyone has used one of the following and how you get on with it and its noise and heat levels.
Knosti Disco Antistat Ultrasonic Record Cleaning Machine
Clearaudio Smart Matrix Silent
HumminGuru Ultrasonic Vinyl Record Cleaning Machine
The moth is the loudest record cleaner I’ve ever heard. My VPI is a bit quieter and I used it in a room similar to yours but I wasn’t listening to music at the same time. I have a degritter now and the cleaning part isn’t too loud, the drying is louder, not as loud as the VPI as it’s just a fan but it goes on for 5 minutes instead of 4 or 5 revolutions. I can at least leave it to it’s own devices and pick up the record when its finished.
If you get an ultasonic keep a vacuum machine to as sometimes you need enzymes to get the much off and vacuum to get the enzyme solution off.
Knosti is fully manual. How loud do you breathe!?
Humminguru emits a horrible high pitched whine. I shut the door whilst it runs (a benefit of it being mostly automatic)
