I want to put them in two sets of racks and was thinking that it should be (something like)
Rack 1 (Left when facing)
NAC52
NAXO 2
Space
nDAC
Rack 2.
Supercap
HiCap
NAP250
NAP250
Would this be a good place to start with the second rack on the right (viewed from the front) so the mains doesn’t run anywhere near the ‘brains’ (apart from the nDAC supply)?
Do you have a Fraim or a rack that would allow you to use 5 shelves on the Brawn side? Just thinking you may get a better result having the 250’s at the top then a space and then Super Cap/Hi Cap…
