My ND5 XS will no longer play Radio Dubai 92, but plays any other station I try - any idea why?
Sounded as if it’s closed down, but the website still is very current
Hi @juanito
It looks like they’ve changed backend servers. I’ve written to the guys at VTuner to let them know that they need to update their database (+ they seem to have the same station twice in the database under 2 different names…).
If you wish to listen to the station now, you can add the station via “naim.vtuner.com” as a custom station using the station URL: http://stream.radiojar.com/6ty5rrkerxquv
Note - this station is regional blocked so won’t work outside the emirates.
Best regards
Steve Harris
Software Director
Naim Audio Ltd.
Ah - thanks, I seem to recall that this happened once before - hopefully it’ll be back up soon.
Dubai 92 is back in action on the ND5 XS - thanks
HI @juanito
We worked with VTuner yesterday and got the issue resolved. It was a bit more complex than it initially looked but all is now sorted.
On next major database resync the duplicate radio entry will go as well.
Best
Steve
