Radio Paradise HD not working
Howdy,
I’m having trouble getting the Radio Paradise HD channels working.
Are others having similar problems?
The lower fi streams work fine.
In the highdef category the main mix plays fine, but you may go about accessing the highdef streams in another way. This is on the new firmware so not the old vtuner streams.
Claus
For RP I now use the RP app and Chromecast to the streamer as I find the app gives a better user experience with the play history, artist bio and lyrics all easily and readily available
Claus: So you can play the hi-def streams. Congratulations.
Elvenrdiblanco: That may be the way to get this done. Claus, evidently can get them to work with the Naim App, but I can’t so going to a different app may be the way to go. Thanks.
