Radio streams not working anymore
Radio streams worked until yesterday. Now not any reaction on selected streams anymore
My NDX2 is on firmware 3.10.1
Have you been using the new internet radio service or the old Vtuner one (although I thought that stopped a while ago)? Is it just presets that are not working or any radio at all?
In any event, it is worth stopping any streams that are running, deleting your presets and reselecting them from the new internet radio options.
I assume you know this, but anything with the warning triangle will not play; simply delete and if you like that station, replace by finding it again.
I had the new streams in place, so not vie the old VTuner.
Now I canceld all Presets, but can not find any new station via search anymore
Hi, it would be worth rebooting your NDX2 and your router to see if that helps.
Qubuz and Spotify work fine
That doesn’t rule out a routing issue :wink:
Resolved.
Removed presets and favourites, powered of NDX2 again.
After restart NDX2 I could search and set readiostations again.
