After the introduction of my P8 and EE8 I’m struggling for plugs.
At the moment I have a switched 2-gang from the wall outputs as follows:
Output 1 = Wireworld Matrix which all my HiFi gear connects to
Output 2 = 4-way extension for lamp + various USB devices
I’m thinking of removing the existing in-wall switched 2-gang and replacing with an un-switched 3-gang which will free up some space, with wall outputs as follows:
Output 2 = SN3
Output 3 = 4-way extension for lamp + various USB devices
Are there any alternatives please (not DIY) or is this a decent resolution?
There seems little to be gained by removing the SN3 from the Matrix. The best thing to do is to install a dedicated spur for the hifi. Is that possible?
I thought of this but the walls are concrete so I’d need to knock out a space for the back-box / channeling for the wiring.
Well, I say concrete but it’s more like Moon rock !!! Even with an SDS drill this took forever the last time I had to cut into it to route some other (non HiFi) cabling.
Yes indeed about the triple sockets fusing.
I’ve got an MK triple in use and the whole thing is fused not just the nearest one.
The OP triple looks like it might be a Volex one they are good quality but I haven’t tried their stuff on the audiophile loop.
Usually MK or Crabtree are the favourites.
Nice tidy idea though.
