Hi,
I used to occasionally play this channel in the past but for a few months now (since last FM update from naim) it no longer plays anything. You can still select the channel but nothing is broadcasted. I have a uniti atom and resaving to presets has not solved it.
I can still listen to it via web so they still do stream.
Hi @Rantanplan
Tried it here and it seems to play fine:
Can you clarify the product being used, the firmware version beimg used and also check that if stored as a preset, reselect it from the radio directory and re-save it as a preset.
Best
Steve
Hi again,
Noticed there is a security warning on the m3u file that the playback is going through from the station. Have removed this so see if it now plays. This might be an ISP side internet safety rule cutting in and blocking the stream.
Best
Steve
I’ve just tried it in Sydney and it’s playing for me. Telstra is my ISP.
It’s started working some time ago, I only checked again… maybe it was this sec. tick
Hi @Rantanplan
This station stream doesn’t have a great record for uptime.
Here is a log of this stations uptime as checked by the deadlinkscanner.
(Times shown are UK time)
Best
Steve
This historic unreliability comes from insufficient convict labour from the UK to service the penal colonies.
