Hello,
I was just looking at three RCA cables.
Tellurium Q Blue II RCA
Atlas Equator RCA
Chord Shawline RCA
I prefer a round analogue sound, without harshness.
Does anyone have experience with any of the cables?
Hello,
Atlas Equator RCA
Chord Shawline RCA
I wouldnât know, I make my own cables (currently Mogami 2497).
Theyâre probably not ideal for you as they contribute very little, allowing a clear detailed and evenly balanced sound thatâs doesnât add harshness, but still essentially devoid of the âround analogueâ colouration to the sound that you requested.
Sorry I canât give a positive indication for any of your suggestions, but at least I can tell you one option to avoid if you want to use cables as tone filters.
Iâm sorry but cables do not âsoundâ of anything.
A bit pedantic or just humor? The only component that sounds is the speaker of course.
I can testify that Chord interconnects are soft and organic sounding. I had the Anthem or Epic, donât remember, and now the Signature tuned array. Some find Chord a bit dull and prefer the Hiline. Not me.
Other here, as @hungryhalibut , have the Tellerium black.
You have a lot of threads on these cables in the search part.
Of the options above, Shawline will be the most detailed but also the brightest in my experience. To get a more mature, accomplished sound from Chord, I would suggest Epic if in budget.
my suggestion would be the TQ of the 3 if you are trying to avoid brightness but keep some detail and an overall balance (I just find Atlas cables a bit too smooth and closed in)
You are the ideal answer the OP was searching for
I found that they did sound different whilst my kitten was chomping on them, some sounded scrunchy, others squelchy and a few crispy. After this feline attention, they sometimes didnât sound at all.
Is it definitely a kitten? Not a gerbil?
Cats just love to cause trouble
QED Signature Audio 40 would certainly also be a good choice.
Does anyone know the cable?
Atlas are excellent cables i use the mavros rca and I would not change it.
