Re-ordering Presets in Naim App
Good morning everyone. Does anyone know if it’s possible to re-order the list of presets (and radio stations) in the Naim App. I can’t find an obvious way to do it. Nor can I find any info on this forum. Which leads me to wonder if it’s even possible.
If anyone can point me in the right direction I’d be very grateful. I would just like to put my own particular favourites at the top of the list.
Touch the three dots on the right side of the app pre-set screen. You will see the station line over slightly to the left, then keeping finger on the station line, you can drag & drop to wherever you want it
Thanks Mike. That worked perfectly for the presets. Oddly though, not for the radio stations.
With both my muso and 272, I can press and hold the preset for about a second and after that, I’m able to move it up or down in the list of radio presets.
Hi again, no not the stations listings
I guess that’s because of a need to have them in alpha/numeric & that’s how the app receives the data.
Well at least the presets are done. Thanks for your help Mike.
