I presently have the opportunity of re-racking my equipment as it’s taken down while I sand the floor boards in the listening room. I also have recently reduced my box count.
So I have a linn axis which I plan to move to it’s own wall mount, this has a Stageline Phono stage. CD5 WITH FLATCAP / SUPERNAIT 2 / arcam rblink for access to tidle.
I will be retaining my current optimum glass rack for now but based on advise woukd like to remove empty shelves.
I photographed the connections of before …so hopefully it will all work after. Also I put a bit of coloured tape on the back next to the relevant socket and corresponding colour on the plug that went into that socket.
Seems easier than trying to understand the connection guide again?
Put the flatcap at the bottom. The other two don’t really matter - just order them so they are most convenient. Do you want the Supernait as the jam in the sandwich or as the top slice?
It’s when you have head units without transformers that it becomes more important - with your boxes they are all powered so it’s far less of an issue. Just keep the Stageline away from the transformers as far as possible.
