Hi!
Are there any good service provider for CB products outside of UK? I live in Sweden and as UK have brexit custom is a trouble.
Thanks, Fredrik
Blockquote
Hi!
Thanks, Fredrik
Blockquote
Have you spoken with your local Naim distributor?
No, I have not. But then they always referred to Naim service in Uk. Then for recap of older stuff it is again some ( none authorized) companies in UK. And these are not possible to use any longer.
Fredrik
If you do customs the way it should then inside our outside EU does not matter for repairs. And I will assume Naim and their distributors know the deal Have you contacted the distributor Instereo in Sweden?
