Recommendations for anti static mats LP12
Any recommendations for anti-static mats for LP12…i just have the original felt mat. Are there have there been any improvements over the years.
Having a bit of a dust/fluff problem…can afford a proper record cleaner.
Can recommend this mat
Colaro mat, but only red.
The Collaro mat is a good alternative to the standard LP12 from Linn. If the logo is too much just turn it over. If it has been stored vertically without side pressure it can form a ripple close to the bottom edge. This did not level out so my dealer kindly supplied a totally flat one. Store it flat if needed to avoid this.
Waiting for mine to arrive from Cymbiosis. Looking forward to testing.
Scott
I agree with this.
Peter
Blasphemy!!..thou shalt worship no other mat than the Linn mat!!
Funny avatar Dan :+1:
Yes recommend Collaro mat. Much better mid range and layered 3D sound stage than the standard Linn felt mat and a lot less static. My LP12 has Kore and Karousel.
