Recommendations for bookshelf speakers with an Atom
Sorry, just realised you used small stands! Please ignore my question…
Yes, it made a big improvement using the small stands, so definitely something worth exploring if anyone’s going to be placing speakers on a desk. From experience you get a lot of reflections off the top of the desk unless you either raise the speaker off the desk or otherwise angle it upwards. Highly recommend the various options from Kanto - https://www.kantoaudio.com/speaker-stands/
Ah yes, the too often overlooked and usually the place where the most difference can be made. The room itself, and placement of speakers. Like most of us, have to find a speaker that “fits” the room. Most of us can make minimal changes to the room (some carpet maybe and for real audio nirvana a couch). So we all make compromises, but at least you figured it out (with some home demos) before you got in too deep. Sounds like a well balanced system, and one you can continue to enjoy.
Try Audio Physic Sparks great with any Uniti.
